Sinumerik Alarm 10601 Channel %1 block %2 zero velocity at block end point during thread cutting
This alarm occurs only when several blocks with G33 follow in succession. The block end velocity in the specified block is zero although a further velocity block follows. The reasons for this can be, for instance:
•G9
• Auxiliary function after motion
• Auxiliary function output before the motion of the following block
• Positioning axis in the block
Please inform the authorized personnel/service department. Modify the NC part program by removing any programmed “Stop at end of block” G09. Modify general machine data 11110 AUXFU_GROUP_SPEC [n] for selecting the output time of an auxiliary function group by changing “Auxiliary function output before/after the movement” to “Auxiliary function output during the movement”.
Bit 5 = 1: Auxiliary function output before movement
Bit 6 = 1: Auxiliary function output during movement
Bit 7 = 1: Auxiliary function output after movement
