Sinumerik Alarm 10610 Channel %1 axis %2 not stopped
An axis/spindle has been positioned over several NC blocks using the POSA/SPOSA instruction. The programmed target position had not yet been reached (“exact stop fine” window) when the axis/spindle was reprogrammed.
Example:N100 POSA[U]=100 : N125 X… Y… U… ; e.g.: U axis still travels from N100!
Check and correct the part program (analyze whether motion beyond block boundaries is appropriate here). Prevent block change by means of the keyword WAITP until the positioning axes have also reached their target position.
Example:
N100 POSA[U]=100
N125 WAITP[U]
N130 X… Y… U…
