Sinumerik Alarm 10630 Channel %1 block %2 axis %3 at working area limit %4
%3 = Axis, spindle number
%4 = String ( + or – )
The specified axis violates the working area limitation. This is recognized only in the main run either because the minimum axis values could not be measured before the transformation or because there is a motion overlay.
– Local alarm reaction.
Program other motion or do not perform overlaid motion.
