Sinumerik Alarm 10651 Channel %1 illegal gantry configuration. Error code %2
%2 = Reason
The gantry configuration set in the machine data is undefined. Gantry unit and reason for objection can be found in the transfer parameter.The transfer parameter is made up as follows.
• %2 = error designation + gantry unit (XX).
• %2 = 10XX => no master axis declared
• %2 = 20XX => no slave axis declared
• %2 = 3000 => different contents in MD 30550 slave axis and master axis
• %2 = 10000 => error: slave axis is geometry axis
• %2 = 11000 => error: competing position axis as slave axis
• %2 = 12000 => error: compile cycle axis as slave axis
• %2 = 13000 => error: gantry axis is spindle
• %2 = 14000 => error: gantry axis is Hirth geared
e.g. error no. 1001 = no master axis declared, grouping 1.
Please inform the authorized personnel/service department. Correct the machine data:MD 37100 GANTRY_AXIS_TYPE
0: No gantry axis
1: Master axis grouping 1
11: Slave axis grouping 1
2: Master axis grouping 2
12: Slave axis grouping 2
3: Master axis grouping 3
13: Slave axis grouping 3
