Sinumerik Alarm 10653 Channel %1 axis %2 gantry error threshold exceeded
%2 = Axis
The gantry following axis has exceeded the error limit (actual value tolerance) specified in MD 37120 GANTRY_POS_TOL_ERROR.
1. Check axis (uneven mechanical movement?)
2. MD not set correctly (MD 37120 GANTRY_POS_TOL_ERROR). A POWER ON is necessary after modifying the MD.
If the axes are not yet referenced, MD GANTRY_POS_TOL_REF is the trigger condition for the error message.
