Sinumerik Alarm 10730 Channel %1 block %3 axis %2 working area limitation %4
%3 = Block number, label
%4 = String ( + or – )
This alarm is generated if it is determined during block preparation that the programmed path of the axis will result in exceeding the working area limitation.
– Local alarm reaction.
a) Check NC program for correct positional data and, if necessary, make corrections.
b) Check zero offsets (current frame)
c) Correct working area limitation via G25, or
d) Correct working area limitation via setting data, or
e) Deactivate working area limitation via setting data 43410 WORKAREA_MINUS_ENABLE=FALSE
