Sinumerik Alarm 10742 Channel %1 block %2 WAB distance invalid or not programmed
Possible causes:
• In a WAB block, the parameter DISR has not been specified or its value is less than or equal to 0.
• During approach or retraction with circle and active tool radius, the radius of the internally generated WAB contour is negative. The internally generated WAB contour is a circle with a radius which, when offset with the current offset radius (sum of tool radius and offset value OFFN), yields the tool center point path with the programmed radius DISR.
– Local alarm reaction.
Modify part program.
