Sinumerik Alarm 10744 Channel %1 block %2 no valid WAB direction defined
The tangent direction for smooth approach or retraction is not defined.Possible causes:
• In the program, no block with travel information follows the approach block.
• Before a retraction block, no block with travel information has been programmed in a program.
• The tangent to be used for WAB motion is vertical to the current machining plane
– Local alarm reaction.
Modify part program.
