Sinumerik Alarm 10745 Channel %1 block %2 WAB end position not clear
In the WAB block and in the following block, the position has been programmed perpendicular to the machining direction. In the WAB block, no position has been indicated in the machining plane.
– Local alarm reaction.
Modify part program. Either remove the position data for the infeed axis from the WAB block or the following block, or program a position in the machining plane in the WAB block as well.
