Sinumerik Alarm 10746 Channel %1 block %2 block search stop for WAB
A block search stop has been inserted between a WAB approach block and the following block defining the tangent direction or between a WAB approach block and the following block defining the end position.
– Local alarm reaction.
Modify part program.
