Sinumerik Alarm 10748 Channel %1 block %2 illegal retract plane with WAB
By means of DISRP a position of the retraction plane has been programmed which is not situated between the safety distance (DISCL) and the starting point (during approach) and/or end point (during retraction) of the WAB movement.
– Local alarm reaction.
Modify part program
