Sinumerik Alarm 10750 Channel %1 block %2 tool radius compensation activated without tool number
A tool T… must be selected so that the control can make allowance for the associated compensation values. A correction data block (D1) containing the correction values (parameter P1 – P25) is automatically assigned to each tool (T number). Up to 9 correction data blocks can be assigned to a tool by specifying the required data block with the D number (D1 – D9). The cutter radius compensation (CRC) is allowed for if function G41 or G42 is programmed. The correction values are contained in parameter P6 (geometry value) and P15 (wear value) of the active correction data block Dx.
– Local alarm reaction.
Before calling the CRC with G41/G42, program a tool number under the address T…
