Sinumerik Alarm 10753 Channel %1 block %2 selection of the tool radius compensation only possible in linear block
Selection of cutter radius compensation with G41/G42 may only be performed in blocks where the G function G00 (rapid traverse) or G01 (feed) is active. In the block with G41/G42, at least one axis in the plane G17 to G19 must be written. It is always advisable to write both axes because, as a rule, both axes are traversed when selecting the compensation.
– Local alarm reaction.
Correct the NC program and put the compensation selection in a block with linear interpolation.
