Sinumerik Alarm 10754 Channel %1 block %2 deselection of the tool radius compensation only possible in linear block
Deselection of cutter radius compensation with G40 can only be performed in blocks where the G function G00 (rapid traverse) or G01 (feed) is active. In the block with G40, at least one axis in the plane G17 to G19 must be written. It is always advisable to write both axes because, as a rule, both axes are traversed when deselecting the compensation.
– Local alarm reaction.
Correct the NC program and put the compensation selection in a block with linear interpolation.
