Sinumerik Alarm 10757 Channel %1 block %2 changing the compensation plane while tool radius compensation is active not possible
In order to change the compensation plane (G17, G18 or G19) it is first necessary to deselect the cutter radius compensation with G40.
– Local alarm reaction.
Insert an intermediate block in the part program using the correction deselection. After the plane change, the cutter radius compensation is to be selected in an approach block with linear interpolation.
