Sinumerik Alarm 10760 Channel %1 block %2 helical axis is not parallel to tool orientation
With active tool radius compensation a helix is only permissible if the helix axis is parallel to the tool, i.e. the circle plane and the compensation plane must be identical.
– Local alarm reaction.
Orient helix axis perpendicular to the machining plane.
