Sinumerik Alarm 10763 Channel %1 block %2 path component of the block in the compensation plane becomes zero
Due to the collision monitoring with active tool radius compensation, the path component of the block in the compensation plane becomes zero. If the original block contains no motion information perpendicular to the compensation plane, it means that this block is excluded.
• The behaviour is correct at narrow locations that cannot be machined with the active tool.
• Modify the part program if necessary.
• Use tool with smaller radius if necessary.
• Program CDOF.
