Sinumerik Alarm 10764 Channel %1 block %2 discontinuous path with active tool radius compensation
This alarm occurs when, with active tool radius compensation, the starting point used for calculating the compensation is not identical to the end point of the preceding block.This situation can occur, for example, when a geometry axis is traversed between two positions as a positioning axis or when, with an active kinematic transformation (e.g. 5axis transformation) the tool length compensation is altered.
– Local alarm reaction.
Modify part program.
