Sinumerik Alarm 10765 Channel %1 block %2 3D tool radius compensation not possible
This alarm occurs when an attempt is made to activate the 3D tool radius compensation even though the option required for this is not fitted in the control.
– Local alarm reaction.
Use another software version. The option cannot be activated by altering machine data because the necessary code is not physically available.
