Sinumerik Alarm 10766 Channel %1 illegal change of surface orientation between block %2 and block %3
%3 = Block number, label
This alarm occurs with 3D face milling when, at the time of block transition, the surface defined in the first block is continued in the second block with the rear side of the surface defined there. The block number in the alarm designates the second block.
– Local alarm reaction.
Modify part program.
