Sinumerik Alarm 10767 Channel %1 block %2 processing with tilt angle unequal 0 not possible
When face milling with a torus milling cutter, the tilt angle must be 0 if the surface normal vector and the tool orientation include an angle that is less than the limiting angle given by the machine data 21082 CUTCOM_PLANE_ORI_LIMIT, i.e. in this case only the lead angle may be unequal to 0.
– Local alarm reaction.
Modify part program. If necessary, use another tool (ball end mill).
