Sinumerik Alarm 10769 Channel %1 block %2 Illegal surface normal vector with 3D tool radius compensation
In 3D face milling, surface normal vector and path tangent vector must theoretically be perpendicular to one another, i.e. they must be at 90° to one another. Since both vectors can be programmed independently of each other, deviations from this angle are possible and allowed. This alarm is generated when the angle between surface normal vector and path tangent vector becomes less than the limit angle given by the machine data 21084 CUTCOM_PLANENORMAL_PATH_LIMIT.
– Local alarm reaction.
Modify part program.
