Sinumerik Alarm 10771 Channel %1 block %2 overflow of local block buffer due to orientation smoothing
This error occurs when more blocks must be buffered than memory space is available.This error can only occur when the software has been incorrectly configured.
– Local alarm reaction.
Increase size of local buffer area.
