Sinumerik Alarm 10772 Channel %1 block %2 illegal orientation change when activating or deactivating 3D face cutting
In face milling, no intermediate blocks with pure orientation change are allowed between the activation block and the first correction block or between the last correction block and the deactivation block (3D tool radius compensation).
– Local alarm reaction.
Modify part program.
