Sinumerik Alarm 10774 Channel %1 illegal tool dimensions with face cutting in block %2
This alarm occurs when illegal tool dimensions are programmed for face milling, e.g. negative tool radius, rounding radius zero or negative for tool types that require a rounding radius, taper angle zero or negative for tapered tools.
– Local alarm reaction.
Modify part program.
