Sinumerik Alarm 10776 Channel %1 block%2 axis %3 must be geometry axis if tool radius compensation is active
%3 = Axis name
This alarm occurs when an axis that is required for tool radius compensation is not a geometry axis. With CUT2DF, the axis can be a positioning axis perpendicular to the machining plane; with all other types of compensation (CUT2DF, CUT3DC, CUT3DF, CUT3DFF), all geometry axes must be operated as such.
– Local alarm reaction.
Modify part program.
