Sinumerik Alarm 10777 Channel %1 block %2 tool radius compensation: too many blocks with suppression of compensation
The maximum permissible number of blocks with active compensation suppression with tool radius compensation is limited by the machine data CUTCOM_MAXNUM_SUPPR_BLOCKS.
– Local alarm reaction.
• Modify part program.
• Modify machine data.
• Check whether SBL2 is activated. With SBL2, a block is generated from each part program line which can lead to exceeding the maximum permissible number of empty blocks between two traversing blocks.
