Sinumerik Alarm 10778 Channel %1 block %2 preprocessing stop with active tool radius compensation
If a preprocessing stop is detected with active tool radius compensation (either programmed by the user or generated internally) and the setting data $SC_STOP_CUTCOM_STOPRE is set, then this warning is issued because in this situation machine movements which were not intended by the user can occur (termination of radius compensation and new approach).
• Continue machining with CANCEL and Start.
• Modify part program.
• Set setting data $SC_STOP_CUTCOM_STOPRE to FALSE.
