Sinumerik Alarm 10782 Channel %1 block %2 illegal curve type with tool radius compensation
This alarm occurs, if an attempt is made to apply the tool radius compensation to a curve type for which this function is not implemented. The only cause at present: Involute with 3D tool radius compensation.
– Local alarm reaction.
Modify part program.
