Sinumerik Alarm 10783 Channel %1 block %2 tool radius compensation type requires orientation transformation
This alarm occurs, if an attempt is made to activate a tool radius compensation which must enable a tool orientation change and the “Orientation transformation” option is not available. This alarm can only occur if one of the following G code is active in the G code group 22:
• CUT3DC
• CUT3DCC
• CUT3DCCD
– Local alarm reaction.
• Modify part program
• Install “Orientation transformation” option
