Sinumerik Alarm 10784 Channel %1 block %2 illegal tool for tool radius compensation with constraint surface
When activating the tool radius compensation with constraint surface, an illegal tool type is active. Only cutting tools of the tool types 1 to 399 are admitted with the following exceptions:
• 111 ball end milling cutter
• 155 torus milling cutter
• 156 torus milling cutter
• 157 torus milling cutter
– Local alarm reaction.
Use another tool.
