Sinumerik Alarm 10793 Channel %1 block %2 second block missing during linear programming with angles
The second block is missing during programming of two straight lines with angle specification. This situation only occurs if the first subblock is also the last block of a program, or if the first subblock is followed by a block with a preprocessor stop.
– Local alarm reaction.
Modify part program.
