Sinumerik Alarm 10794 Channel %1 block %2 angle specification missing in second block during linear interpolation with angles
The angle is missing from the second block during programming of two straight lines with angle specification. This error can only occur if an angle was programmed in the preceding block, but no axis of the active plane was programmed in that block. The cause of the error may therefore also have been the intention to program a single straight line with an angle in the previous block. In this case, exactly one axis of the active plane must be programmed.
– Local alarm reaction.
Modify part program.
