Sinumerik Alarm 10795 Channel %1 block %2 end point specification during angle programming contradictory
During programming of a straight line, both positions of the active plane and an angle were specified (the position of the end point is over-specified), or the position of the programmed coordinate cannot be reached with the specified angle. If a contour consisting of two straight lines is to be programmed with angles, it is possible to specify the two axis positions of the plane and an angle in the second block. The error can also occur if, due to a programming error, the preceding block cannot be interpreted as the first sub block of such a contour. A block is interpreted as the first block of a two-block contour if an angle,but not an axis of the active plane, was programmed, and if the block is not already the second block of a contour.
– Local alarm reaction.
Modify part program.
