Sinumerik Alarm 10810 Channel %1 block %2 master spindle not defined
The function “Revolutional feedrate” (with G95 or G96), or “Rigid tapping” (with G331/ G332) has been programmed, although no master spindle is defined from which the speed could be derived. For the definition the MD 20090 SPIND_DEF_MASTER_SPIND is available for the default or the keyword SETMS in the part program, thus allowing each spindle of the channel to be redefined as master spindle.
– Local alarm reaction.
Preset the master spindle with MD 20090 SPIND_DEF_MASTER_SPIND[n]=m (n … channel index, m … spindle no.) or define it with an identifier in an NC part program before a G function that requires a master spindle is programmed. The machine axis that is to be operated as a spindle must be equipped in MD 35000 SPIND_ASSIGN_TO_MACHAX[n]=m (n … machine axis index, m … spindle no.) with a spindle number. Additionally, the MD 20070 AXCONF_MACHAX_USED[n]=m (n … channel axis index, m … machine axis index) must be used to assign it to a channel (channel axis index 1 or 2).
