Sinumerik Alarm 10820 Channel %1 rotary axis/spindle %2 not defined
Revolutional feed has been programmed for contouring and synchronous axes or for an axis/spindle. However, the rotary axis/spindle from which the feed is to be deduced is not available.
– Local alarm reaction.
Correct part program or set the setting data 43300 ASSIGN_FEED_PER_REV_SOURCE correctly.
