Sinumerik Alarm 10861 Channel %1 block %3 velocity of positioning axis %2 is zero
%2 = Axis
%3 = Block number, label
No axis velocity has been programmed and the positioning velocity set in the machine data is zero.
– Local alarm reaction.
Please inform the authorized personnel/service department. Enter a different velocity in machine data 32060 MA_POS_AX_VELO.
