Sinumerik Alarm 10862 Channel %1 block %2 master spindle also used as path axis
A contour has been programmed that also includes the master spindle as contouring axis.However, the velocity of the contour is derived from the rotational speed of the master spindle (e.g. G95).
– Local alarm reaction.
Modify the program so that no reference is possible to the program itself.
