Sinumerik Alarm 10881 Channel %1 block %2 overflow of local block buffer when inserting chamfers or radii
Between 2 blocks containing the contour elements and to be joined with a chamfer or a radius (CHF, RND), so many dummy blocks have been programmed without contour information that the internal buffer is too small.
– Local alarm reaction.
Modify part program such that the number of dummy blocks is reduced.
