Sinumerik Alarm 10883 Channel %1 block %2 chamfer or fillet has to be reduced
This alarm is output, if at least one of the relevant blocks when inserting chamfers or radii is so short, that the contour element to be inserted must be reduced against its originally programmed value. The alarm occurs only if bit 4 is set in the machine data $MN_ENABLE_ALARM_MASK. Otherwise, the chamfer or radius is adapted without an alarm being output.
– Local alarm reaction.
Modify NC program of continue program without modifications after CANCEL and Start or with Start alone.
