Sinumerik Alarm 10890 Channel %1 block %2 overflow of local block buffer when calculating splines
The maximum permissible number of empty blocks is limited by a machine data.
– Local alarm reaction.
• Modify part program
• Modify machine data
• Check whether SBL2 is activated. With SBL2, a block is generated from each part program line which can lead to exceeding the maximum permissible number of empty blocks between two traversing blocks.
