Sinumerik Alarm 10900 Channel %1 block %2 no S value programmed for constant cutting speed
If G96 is active, the constant cutting speed under address S is missing.
– Local alarm reaction.
Program constant cutting speed under S in [m/min] or deselect the function G96. For example, with G97 the previous feed is retained but the spindle continues to rotate at the current speed.
