Sinumerik Alarm 10910 Channel %1 block %2 excessive velocity of one path axis
With active transformation, an excessive increase in velocity occurs in one or several axes, e.g. because the path passes close by the pole.
– Local alarm reaction.
Divide the NC block into several blocks (e.g. 3) so that the path section with the excess is as small as possible and therefore of short duration. The other blocks are then traversed at the programmed velocity.
