Sinumerik Alarm 10913 Channel %1 block %2 negative feed profile is ignored
The given feed profile is in part negative. However, negative path feed is not allowed. The feed profile is ignored. The specified feed block end value is taken when traversing over the entire block.
– Local alarm reaction.
No action is usually necessary. The alarm message indicates an error in the programming, however, and this should be corrected.
