Sinumerik Alarm 10933 Channel %1 block %2 contour program does not contain enough contour blocks
The contour program contains:
• Less than 3 contour blocks with CONTPRON
• No contour blocks with CONTDCON
– Local alarm reaction.
Increase the size of the subroutine with the stock removal contour to include at least 3 NC blocks with movements in both axes of the current machining plane.
