Sinumerik Alarm 10940 Channel %1 block %2 curve table %3: delete/overwrite not possible
%3 = Number of curve table
The curve table can only be deleted if it is not active in a link.
It is necessary to deactivate all links that are being used by the curve table to be deleted.
