Sinumerik Alarm 10941 Channel %1 block %2 curve table %3: NC memory full
%3 = Number of curve table
The free dynamic disk space is exceeded during definition of the curve table.
Please inform the authorized personnel/service department. Delete curve tables that are no longer required, or reconfigure the disk space for the curve tables. The curve table definition process now has to be repeated; see machine data: MD MN_MM_NUM_CURVE_TABS, MD MN_MM_NUM_CURVE_SEGMENTS, MD MN_MM_NUM_CURVE_POLYNOMS.
