Sinumerik Alarm 10944 Channel %1 block %2 curve table %3: illegal transformation
%3 = Number of curve table
It is impermissible to use a transformation in a curve table if the leading axis or following axis programmed in CTABDEF is involved in the transformation. Exception: TRAANG.
Correct NC part program.
