Sinumerik Alarm 10946 Channel %1 block %2 curve table %3: no contour defined
%3 = Number of curve table
No movement for the leading axis was programmed between CTABDEF and CTABEND.A curve table is not permitted without a contour.
Correct the part program and start it again.
