Sinumerik Alarm 10947 Channel %1 block %2 curve table %3: contour not continuous
%3 = Number of curve table
The contour in a curve table must be continuous. Incontinuity can occur, for example, as a result of activating a transformation.
Correct the part program and start it again.
